4-1-8 Blower fan not working '95 854T
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
1995 854T, 255,000 miles, ECC equipped.
The HVAC fan stopped working. The REC and A/C would flash for 20 seconds as designed to indicate a fault.
Read the codes from B1 under the hood and got a 4-1-8 "No control signal to blower fan power stage"
I looked up the diagnostic procedure but got kind of lost.
Do I need a specific testing tool to continue?
The procedure refers to checking between "test unit pin No. 42 and power stage connector terminal 1A"
Seeing "test unit pin", I'm thinking I don't have the tools.
Maybe someone has some advice...
Thanks
'84 Prelude
'06 MPV
'13 Ford Focus SE
alschnertz
I should have added that I pulled the blower motor and found that it spins freely.
Also put 12V to it and it ran without any weird noises.
'84 Prelude
'06 MPV
'13 Ford Focus SE
