Hi all. I need some help. I have a 91 240. After car warms up my car will die. I have had it die while idle, while accelerating, or while putting in gear after parked.
I have replaced fuel pump(external), fuel filter, in tank pump, strainer, fuel pressure regulator, and fuel relay.
What am I missing? I am losing sleep over this. Please any help?
1991 240 dies when warm - tried both fuel pumps, relay, regulator
My 90 740 was doing that, replaced 1323592 Noise Suppression Relay (AKA: Radio Suppression Relay or "RSR"). fixed it, replaced relay and relay connector, both relay and connector were bad, I just used a relay with the same specs., cost a few bucks, works the same as the 65 dollar one.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Radio suppression relay supplies power to the injectors, among other things.joedrt77 wrote: 03 May 2017, 13:58 My 90 740 was doing that, replaced 1323592 Noise Suppression Relay (AKA: Radio Suppression Relay or "RSR"). fixed it, I just used a relay with the same specs., cost a few bucks, works the same as the 65 dollar one.
1988 Volvo 760 Turbo Wagon
dougburgy
- Year and Model: 1983 242GL
IAC (idle air control)? Sounds a lot like symptoms of bad IAC, which is up on throttle body. Maybe research that, specific to your car and see if others have reported same. Check all vacuum lines and electrical plugs in engine bay. Injectors, spark plug wires (at plug and dist), etc.
When you say it dies...do you mean like engine stalls...but all other electrical seems fine?
- 728 Views
Last post by 1stgenxxx
- 734 Views
Last post by s10lowrider1994
- 2056 Views
Last post by Bdsexton06
- 13 Replies
- 5337 Views
Last post by volvolugnut
- 1269 Views
Last post by jenkinskg
