Starting problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
dmpcjbc
Starting problem
Post by dmpcjbc »
1992 740 Wagon: Just bought, running fine two days. Ran a little rough last night & now no start. At first warning lights did not come on. Now they do. Tries to start but NG. No spark at coil. Tried a used coil & same problem, no spark.battery fine & everything else seems OK. Anyone have any ideas?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you 12 volts at the low tension side of the coil?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
wojeepster
Post by wojeepster »
Unplug air mass sensor and see if it starts. Unplugging puts it in limp home mode. If it starts unplugged but will not run plugged up air mass sensor is bad. Used one about $30 at www.car-part.com
If no difference. Give the large white relay second row behind ash tray near drives knee at few taps. If it starts you need a fuel pump relay.
