Volvo 850 T-5R manual transmission swap completed... Topic is solved
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Completed my manual transmission swap on my '95 Volvo 850 T-5R. It was a solid 3 day job with 2 people. Would have been easier if I would have dropped the sub frame on the ground or pull the engine and transmission out of the top together. We had the car on jack stands and lowered the sub frame.
Since the swap, my city gas mileage has gone up about 20%. I had the car tuned to the '98 T5M tune so I lost a little boost but I it is not looking for the auto trans. I installed some rebuilt blue injectors but need to install whites. I now have a set of whites that are going to be tested and cleaned, rebuilt if necessary.
When we got done, the reverse lights did not work, blew the fuse. Got it working, the cut wire ends were not clean so that may have caused it to short out.
The cruise does not work, not sure why. Will try get that fixed soon.
My highway mileage is the same at in the auto because the final drive of the 5 speed is the same as the 4 speed auto.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Can't wait to see some videos of you peeling out, Robert! :)
Retired:
2015 Volvo S60, T5, 85K
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
the swap that many want to do but few succeed, congrats
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Welcome to the club :P
rspi
Post by rspi »
polskamafia mjl wrote: 04 May 2017, 15:11 Welcome to the club :P
Thanks. What did you do for the ECU mod?
polskamafia mjl
Nothing yet. I've just been living with the CEL for now. How has your tune worked out so far? Does the engine hold revs a little longer or did you just have it tuned to not look for a TCU?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Like I said on one of the videos, glad to hear it went well! I hope to swap mine eventually.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
rspi wrote: 03 May 2017, 18:21 I installed some rebuilt blue injectors but need to install whites. I now have a set of whites that are going to be tested and cleaned, rebuilt if necessary.
Don't bother, blue injectors flows exactly the same as white injectors. Search for their part numbers
http://www.witchhunter.com/injectordata1.php
Only the fuel pressure regulators used with white/blue injectors are different.
You need to modify the relay.
http://volvospeed.com/vs_forum/topic/78 ... nt=2087375
rspi wrote: 04 May 2017, 17:28
I know this question is not directed to me, but the 627 Euro Spec 850 R calibration works with manual transmission without the RPM hold and no CEL. I also modified my 627 calibration so it works with the white/blue injectors and with the correct fuel and MPG gauge. Downside is the 627 Euro Spec 850 R calibration have NO obd II capabilities, so I would not use it with 96/97 cars.
viewtopic.php?t=76990
85 GLH, 367 whp
00 Insight, 72 mpg
bmdubya1198
tryingbe wrote: 04 May 2017, 21:57 Don't bother, blue injectors flows exactly the same as white injectors. Search for their part numbers
Really? I thought the blue injectors were 395cc while the whites are only 350cc? https://www.fcpeuro.com/blog/posts/red- ... ctor-guide
tryingbe
Has thanked: 1 time
Post by tryingbe »
bmdubya1198 wrote: 05 May 2017, 07:22
You should really read what you post.
White & Blue
White and Blue injectors flow exactly the same.
High fuel pressure means injectors will flow more, HOWEVER, fuel pump will flow less.
85 GLH, 367 whp
00 Insight, 72 mpg
