Multi misfire - weak idle T6
Jrsimp78
Year and Model: Xc90 t6 2003 bi fuel
Post by Jrsimp78 »
I have a weak idle and occasional misfire code (multi). The initial fault was the intake manifold gasket. I replaced it and this seemed to fix the problem........ but only for 3 days. I therefore suspect another leak but there is nothing obvious. - I've tried pressure testing by plugging the main boot pipe and introducing pressure into the brake servo port.... No clear sign of leakage.
Does any one know a good way to test the invisible PCV pipe that goes from the PcV valve on the underside of the manifold to the catch can.
- Positive pressure into the dipstick tube ??
- It's also a bit low on power.
Could the fuel filler cap seal cause such issues ?
also with most car's I've worked on , they don't like it if you remove the oil filler when running .. My T6 continues exactly the same with or without the oil filler cap- I've tried the glove test- at idle the is a mild vacuum. I you blip the throttle there is momentary positive pressure. -- Is this all normal for a T6 ?
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
I believe the fact that at idle the glove has mild vacuum and does not blow up is excellent. these kind of mystery symptoms are the toughest to figure out.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
