WRONG ABS Module WORKS :D
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
My 1998 V70 ABS module has been repaired 3 times by me, each time the repair lasts a few weeks. SO i decided to buy a re manufactured one, it arrived and i fitted it and i still have warning lights on??...I also tried another module that i know works but the part number is different, the lights go off however when i press the tracs switch the tracs off light comes on then goes off....is the ABS system working, i wont be testing it until daylight and a gravel road is some distance from me??
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Get the codes read and see what the issue is first? It could be a wheel sensor is bad.
85 GLH, 367 whp
00 Insight, 72 mpg
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
+1 to first answer, make sure rest of the system is ready
Sorry to jack the thread: but you mention another module with different part number turns off ABS light, but leaves TRACS disabled; what is the part number?
The module you have pictured is the same as that on my '98 non-TRACS, FWD.
9140773 6840
10.0946-0400.3 3X2969
but the S# below the barcode is different. Is this the software load?
If a module is found away from a car, how can we identify its application?
Current Volvos:
darylrobert
I have used my scan tool and there are no codes.should there be a fault code?...
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You must drive the car after abs/tracs module has been installed.
That way the control unit will perform self-check test and if everything is ok it will turn off abs/tracs light.
Don't mix modules with different PART numbers.You will fry something if not allready.
Contact matty-moo from this forum for details and instructions.He rebuilds these and knows everything about them.
@FLXC90
That "S" you're referring to should be a serial number and it's not relevant at all.
The most important thing is Volvo part number and the number below "Control-unit abs" match the old unit.
Other than that....that it came from a '96-'99 car with abs/tracs.'99 and after are different.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
tryingbe wrote: 05 May 2017, 06:51 It could be a wheel sensor is bad.
Never seen a single one gone bad on these cars.
It's always abs/tracs module on models from '96-'99.
Older abs units from '91-'95 also rarely fails.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
darylrobert wrote: 05 May 2017, 07:50 I have used my scan tool and there are no codes.should there be a fault code?...
Is your scan tool able to get ABS, SRS, and other level 2 system codes? Most are just good for emission problems.
misha
Post by misha »
You will need a special Volvo tool to be able to access other modules in the car.
Standard code reader will have access just to ecu.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
The Tracs button always does that with a non-traction module installed. It's normal.
Abs light off, system working.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
FLXC90
Post by FLXC90 »
From Misha
@FLXC90
Matty Moo wrote: 05 May 2017, 21:18 The Tracs button always does that with a non-traction module installed. It's normal.
So what I see is this is a 96-98 non-Tracs module, If you want ABS and Tracs to work, you need a different box. (what's Matty Moo's shipping to Oz I wonder?)
Current Volvos:
