1984 volvo 244 b23f m46
Okay so im new to the forums and i need help i would usually never ask for help but im stumped on this my 84' volvo 244dl does not want to run on start up it shutters/jumps and sometimes stalls i try to solve the promblem by giving it a little throttle and the pedal just goes to the floor with no reaction like the throttle cable isnt even connected but once i let it run in that horible manner for about 5-6 minutes until warm idle will stablize and throttle response comes back and im off for a drive, FPR checks out MAF clean long before this issue, TB cleaned, pumps and relay seem to be okay, i just dont know. Help please
Is this a fuel problem? 1984 Volvo 244 b23f m46
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Generally, this suggests there is not enough fuel entering cylinders, or too much air entering cylinders.Dustin240 wrote: 06 May 2017, 13:391984 Volvo 244 b23f m46...does not want to run on start up it shutters/jumps and sometimes stalls....5-6 minutes until warm idle will stablize and throttle response comes back and im off for a drive,
This might suggest your IAC is stuck open, maybe too many air leaks (intake mainifold, injector o-rings shot, tubing sucking air, or clamps not secured, etc.
So, pull the vacuum hose off of Fuel Pressure Regulator, and start it cold, and see what happens.
- 93Regina
Possible reasons:
1. Lower fuel pressure...due to pump(s) or FPR bypassing
2. Vacuum line sucking air...or maybe brake-booster's bladder is busted (so, unplug its line at intake, and plug intake hole there)
dougburgy
- Year and Model: 1983 242GL
Just shade tree mechanic here....but I'd say if you had serious vacuum issue or low fuel pump pressures (pre or main) you would have issues all the time, not just at start up and warm up. At least some issues when you "go for a drive". Do these have an inline fuel pump check valve? If not, while sitting you might be going down to zero psi in fuel rail. Then...you have to wait for pre and main pumps to do the job of getting fuel back up to pressure for injectors to function properly, etc.
Also, how's basic tune up state? new plugs? new wires? New cap and rotor? Things inside the dist cap nice and clean/dry?
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Low fuel pressure caused at least one stall on cold start up on my 1988 Volvo 760 Turbo wagon. I was experimenting with a 2.5 bar BMW fuel pressure regulator.dougburgy wrote: 15 May 2017, 14:19 Just shade tree mechanic here....but I'd say if you had serious vacuum issue or low fuel pump pressures (pre or main) you would have issues all the time, not just at start up and warm up. At least some issues when you "go for a drive". Do these have an inline fuel pump check valve? If not, while sitting you might be going down to zero psi in fuel rail. Then...you have to wait for pre and main pumps to do the job of getting fuel back up to pressure for injectors to function properly, etc.
1988 Volvo 760 Turbo Wagon
- 93Regina
Open Loop and Closed Loop are two different states...in Closed Loop operation, ECU can compensate within its design parameters.dougburgy wrote: 15 May 2017, 14:19....but I'd say if you had serious vacuum issue or low fuel pump pressures (pre or main) you would have issues all the time
At startup, cold, symptoms suggest extra air, or low fuel pressure..."does not want to run on start up it shutters/jumps and sometimes stalls....5-6 minutes until warm idle will stablize and throttle response comes back and im off for a drive," which suggests it runs better in Closed Loop.
dougburgy
Makes sense. If when cold these are in open loop and ecm looking for info mainly from maf, coolant temps, etc...extra air from someplace else sounds like it could really mess with fuel/air ratio. But enough to keep if from starting, jumping, stalling? Must be a nice size leak. Does sound like lack of fuel...and he said fuel pumps seemed to be OK. That is why I was thinking starving due to something else in fuel system like clogged up fuel filter, bad post-pump check valve (allowing pressure in rail to bottom out), etc. Please let us know what you find out.
- 93Regina
Also, the thermostatic flapper valve, if still intact, will stick in "heat mode" when defective, so, as engine warms, the air density decreases, which means less fuel would be required, but AMM should detect this, until it is destroyed.
Without specific tests being performed, these threads can go round, and round.
Btw OP, I've got a LH 2.2 AMM and ECU (Auto), and even Chrysler Box
dougburgy
and round and round
But....good to throw things at them to look at and research further. PO gutted my thermo flapper before I got my 242. Doesn't bother me a bit. I'm in Oregon, so pretty mild. Plus car is garaged. Those can stick open, or closed, depending on when wax plunger thingy goes bunk...causing some very odd symptoms (and possible damage from overheating, etc)
- 2823 Views
Last post by 93Regina
- 355 Views
Last post by volvolugnut
- 1353 Views
Last post by matthew1
- 4617 Views
- 1866 Views
Last post by 69bqda408
