Loud noise under hood
frustrated
- Year and Model: xc90,2007
I have an 07 xc90 3.2. There is a very loud noise coming from under the hood. Noise is there hot or cold and gets louder while driving. I replaced the belt tensioner and idler pulley a couple of months ago because I thought that's what the noise was. Noise still present after I replaced those parts. I took serp belt off and started engine and noise goes away. Ac comp checks out ok. Ps pump seems fine also. Everything that moves with the belt is ok. I thought it may have something to do with the alternator but it still spins when belt is off so that eliminates that also. Any suggestions???
Even if they spin freely, one of the belt-driven accessories could still be the problem. I remember that when the bearings in my wife's alternator went out it sounded like an air raid siren but still spun fairly well. Based on your description, anything that gets spun by the belt is suspect. I would get a mechanic's stethescope (listening to the end of a long screwdriver will also work) and start probing each of the accessories while the engine's running. Be careful of the belt, naturally. That will let you hear exactly what's going on in each component and pinpoint the noise. Probe everything, even the tensioner pulley, so you can objectively rule them out.
Let us know what you find!
frustrated
I used a stethoscope and probed around all the moving parts. The noise appeared to be coming from the ac comp. So I ordered one and changed it out,only to have the same exact noise. I returned it and put another one on..still has the same noise. I don't see three ac compressors making the same exact noise. I removed the alternator to check the coupling and the bolt that attaches the drive gear to the pulley that drives the serp belt. All appears to be ok. The noise is extremely loud at the ac compressor, like something is going to fly apart loud. But like I said after three of them and still the same sound I have my doubts.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Isn't there a chain drive on the rear of the 3.2 that runs the compressor?
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
frustrated
No the serpentine belt runs it. I'm not sure about a chain drive but something drives the alternator and the serpentine belt from inside the cover. That's why I removed the alternator to check the coupling and the bolt for the pulley that drives the serpentine belt
- June
There is R.E.A.D. at the back of the 3.2 that runs belt driven items that is powered by the timing chain. At least on the S80 3.2. It was one of the things that I did not like about that engine. I think R.E.A.D. stands for rear engine accessories drive. It's been a while since it was explained to me but might be your noise as I have heard they go bad. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Can you upload a video on Youtube, that would help us better understand the kind on noise. Have you refilled with refrigerant and the correct amount of oil the a/c system?
frustrated
The compressor was supposed to have oil already in it. I assume it has the right amount
ALF1
- Year and Model: XC90 2003 2.5
- Been thanked: 5 times
Check the pulley on the alternator shaft. It's one of those that guide the serpentine belt. My 2003 XC90 AWD 2.5T had a noise in the engine compartment at 210,000 miles that I could not identify. Got louder and louder. I finally noticed the serpentine belt pulley on the alternator started to float axially in and out. Drove home carefully, but not in time....the pulley came off and the serpentine belt fell off. Drove home under battery only and eventually a tow. The alternator pulley bolt had loosened and then the imbalance ground off the threads on the alternator shaft. The pulley is threaded onto the alternator shaft and then bolted on. I didn't notice the bolt or its loosening because they put a plastic cover over the bolt head. I suggest that you pry off the plastic cover on the end of the alternator pulley and tighten the bolt. If it needs a lot of tightening, you may want to remove it and inspect the shaft threads.
- 2198 Views
Last post by cuhfs
- 18 Replies
- 1204 Views
Last post by paul1149
- 4196 Views
Last post by rred
- 277 Views
Last post by anothevolvofan
- 1663 Views
Last post by jonesg
