I'm trying to decode the line where it spells out the code for suspension, etc. Every site I've found thus far has 8-digit codes, whereas this is 12. It's a 2005, but the tag is under the hood on driver side. Made in Ghent, Belgium. Anyone have a decoder ring? Looking for rear springs/shocks. Rebuilding suspension / brake system:
1111X3314731
Any help mucho appreciated.
Option code decoding
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
JRL
- Year and Model: Several
- Been thanked: 16 times
The bottom line on that tag is the suspension/chassis code, ignore those four"1's"
That number looks to be right, a dealer will need to tell you what to order, there is no "decoder sheet" out there.
VIDA may, not sure.
Email me (email in my signature below) with what you want, let me see what I can find out at the dealer tomorrow.
You want Volvo replacement part numbers?
I also will need your VIN plus the year and and model
Include that chassis code so I can copy and paste it all to a list that I will make up and print out
VIDA may, not sure.
MarcM
Sent PM with dataplate transcription. After I posted, I did find the dataplate info sheet. I didn't post this, because the info still doesn't jive.
What threw me off was how it says "1111X3314731"
6&7 is 33
7&8 is 14
FCP shows nothing under these 'options' for rear springs/shocks. But if I offset one more #, the items DO refer to those two items:
31 (springs)
47 (shocks)
I'm not up for a $600+ mistake.
6&7 is 33
7&8 is 14
31 (springs)
47 (shocks)
2005 S60 2.5T AWD
IPD mods:
IPD mods:
- 1871 Views
Last post by Patrick961
- 1146 Views
Last post by bmdubya1198
- 49 Replies
- 9402 Views
- 26513 Views
- 12 Replies
- 4929 Views
Last post by wizechatmgr
