Brake pedal gradually sinks
xyourobob
- Year and Model: 2004 XC90, 2011 XC60
- Been thanked: 4 times
My 2004 XC90 T6 is generating some weird braking symptoms - While I am stopped at a light I can hear the booster vacuum assist pump come on and when the pump does come on the brake pedal sinks a little, the pump will shut off for 15 - 30 seconds and then kicks back in and the pedal sinks some more. This keeps happening until I start driving again. Does anyone know what could be causing this to happen?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The pump switch goes faulty quite often... I would also inspect all hoses going to that switch
https://www.amazon.com/Genuine-Volvo-Va ... B00IFHYLY6
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Have you been loosing fluid?
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
xyourobob
No I have not been losing fluid, someone on another board suggested I turn the key on with the engine off and see if the assist pump kicks in. It didn't until I touched the brake then it kicked in, I'm told this suggests the diaphragm in the brake booster is leaking. I'm not sure if I have to change the booster itself or whether the diaphragm itself can be replaced. Does anyone have instructions for this job?
- 672 Views
Last post by valvolvo70
- 1063 Views
Last post by kwells114
- 1149 Views
Last post by zack1970
- 4085 Views
Last post by 204015953
- 4738 Views
Last post by SUBdude
