TOYOTA TIS Techstream Use tips
Forum rules
obdtool
Year and Model: 2005
Post by obdtool »
Firmware 2.04 version is original Xhorse MINI VCI TOYOTA single cablem,it support Toyota cars after 1996 year,and can do reset immo, or make customization to cars.Here we share how to install toyota tis software step by step.
How to Install V10.30.029 TOYOTA TIS Techstream?
1.Insert CD,and start Toyota Techstream 10.30.029.exe.
toyota tis techstream
2.Choose the language you want.Continue to finish installing Techstream.
toyota tis software install
3.Install MINI VCI Driver.Open MVCI Driver for Toyota.
toyota tis software
4.Copy MainMenu application.Open Techstream Properties.Click Find Target.
Paste MainMenu application in C:/program files/toyota diagnostics/techstream/bin, confirm file replace.
Close bin folder and Techstream Properties
Connect the xhorse mini vci Toyota device to the vehicle and then install the driver
5.Start Techstream on desktop,then choose NO.Select Setup->Techstream configuration.
install-toyota-tis-techstream-10-30-029-4
6.Run the “Techstream” on desktop.Select the area “Europe”. Select the language you want.
xhorse toyota tis
7.The register information, you can write everything you want, fill all the blanks, then OK.
xhorse mini vci toyota
8.Interface Select. Click the [Setup] menu, then click the [VIM Select], then select the [Xhorse-MVCI] in the drop down list of “Interface Setup”, then Click [OK]
Original Article url:How to Install V10.30.029 TOYOTA TIS Techstream?
