Hi.
I have a 2008 s80 4.4l and need to replace the turn signal relay (flasher) but I'll be darned if I can locate where it is. So far nobody has been able to help. I would like the location and part number as well as how many pins, I have seen 3 pin, 4 pin and 5 pin mentioned but not certain. Help is greatly appreciated.
turn signal relay location Topic is solved
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
You can not replace relay for turn indicators. There are not relay for this indicators. Can you explain what happened with your car?
If you mean relay for sound only, this relay in the DIM (dashboard). If you can to do solder work, good luck.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- yagger
You need to change circuit of CEM a little bit. There are load resistors for check loads your turns lamps. If you know how to do this, good luck. ))
- 4376 Views
Last post by WA-Boater
- 2722 Views
Last post by techedbob
- 728 Views
- 8889 Views
Last post by rhubarb
- 1397 Views
Last post by Biovince49
