Where could I buy or rebuild CEM for 07 XC90
nyc1836
Year and Model: 2002VOLVO S80 T6
Post by nyc1836 »
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
What is the issue leading to it needing a CEM?
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
What happened with your CEM?
For example
For example
ebay cem-h.jpg (526.88 KiB) Viewed 10102 times
nyc1836
Post by nyc1836 »
About 6 weeks ago we drove the SUV from Texas to Miami stayed there 2 weeks and came back total about 3000 miles the anti skid service and DSTC came on several times car drove fine the other night my wife was 5 minutes from house started car abs check engine and other lights came on she told me to check.I tried to start car no luck Brake Failure - We diagnosed the car no communication to main computer with OBD even though I plugged in another used computer which started to read codes but wouldn't stat because probably needs programming so we put back old computer started car once and then again same problem no communication I also took it to Volvo specialist not dealer who is very reasonable also said it needs CEM
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
have a look here for a small relay on the CEM that is known to go bad (not the whole CEM) post #7
http://forums.swedespeed.com/showthread ... -shuts-off
and here for DEM corrosion on the AWD system (read post Sep 26th, 2010, 20:50)
http://www.volvoforums.org.uk/archive/i ... 00774.html
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
One other thing to test are the shunts. Although my experience was with an XC70 - after much chasing (including rebuilt CEM) I found out a shunt was bad and it was taking everything down.
THolland
Year and Model: 2005 S60 2.5T AWD
Has thanked: 3 times
Post by THolland »
SuperHerman - just wondering where was the shunt located that you replaced?
FREEBUSINESSES
Year and Model: 2005 XC90
Been thanked: 3 times
Post by FREEBUSINESSES »
Yes, please, where are shunts, have a CEM issue, cleaned all corrosion from typical water damage from leaks on PC last year, solved problems, sealed CEM better, but now it won't crank and I went through everything, new starter, checked starter relay, fuse, changed battery, everything else works, just won't crank, so looking for more possibilities.
