Does anyone have a good diagram of the 760 strut bearing assembly? I need to verify all the washers/spacers are in the right spot. I had a shop put new struts and bearings on, and now there is a massive clunk in the front end if you hit large bumps.
Thanks,
Spenser
760 Strut Bearing Diagrams?
Bluevanacd2005
- Year and Model: 1983 760
I like curves on my women, not my cars
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
www.swedishautoparts.com/740/Volvo-740- ... front.html
Just scroll down the page to diagram of front strut parts. 740 is the same as 760 for front strut parts.
1988 Volvo 760 Turbo Wagon
Bluevanacd2005
Ok thanks, that is actually what I kept getting when I was googling. I just wasn't sure it was right. It seems like when weight is taken off the struts causes some type of shifting and a clunk. If I remove the plastic cap on top, I can see the end of the strut rod, the nut, and a small washer under it. I didn't know if there was supposed to be a larger washer to keep the strut up when it's unloaded. Doesn't seem like it. Maybe the nuts are loose? The entire rod spins when I put a socket on it.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
There was a $30.00 tool kit to do this on Amazon, but I can't find it now.
Here is a high dollar tool that will work. OTC 7544 24mm Strut Rod Nut Socket
As stated, "Great tool to remove those 24mm strut nuts in strut mounts with no space for a box end wrench.
The socket's outside 1/2 inch drive flange works with a 1/2 drive breaker bar, torque wrench or long ratchet while the opening in the center of the socket allows the use of a 10mm socket with another ratchet to hold the strut rod in place while removing / tightening the outer 24mm nut."
Read the instructions on how to do this...
Bluevanacd2005
"Were the strut mounts replaced?"
I don't think so.
Thank you for the tip on the tool
I don't think so.
- 16 Replies
- 2964 Views
Last post by Bluevanacd2005
- 16 Replies
- 4351 Views
Last post by JRev
- 659 Views
Last post by precopster
- 1110 Views
Last post by oragex
- 1139 Views
