C70 t5 2001 top shock mount replacments Topic is solved
belskee
Year and Model: C70 t5 00
Post by belskee »
Hi all, I'm needing to replace the strut mounts and spring seats on my c70 t5, can the xc90 mounts be used?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Probably all you can buy at Volvo parts suppliers.
belskee
Post by belskee »
Oddly enough the parts supplier I was using only did aftermarket mounts and seats, I had a problem with them before over a cam position sensor, they tried to assure me that the one they had would fit even though I could clearly see it wasn't the correct part.
Anyhow I have found a good deal on oem xc90 top mounts and lower spring seats, I've read on here that the xc spring seats are better but that was for a v70, also doesn't mention if the xc top mounts can be used or if they're any better.
Are you saying that both will fit then yes? Thanks for the quick reply, didn't want to get down in the job only to find the parts won't fit
rspi
Post by rspi »
The XC90 spring seats should fit fine. I put them on a 2000 XC V70 a few months ago.
