I'm considering buying a 2004 XC70 with 98k miles.
Clean no accident carfax with regular scheduled maintenance performed.
Recent work includes cabin air filter, plugs, power steering change, new tires, front/read pads.
What other items should be coming due ? Timing belt? engine mounts?
2004 XC 70 Purchase
JRL
- Year and Model: Several
- Been thanked: 16 times
Well, that's bad right there.
These cars (and most AWD cars) need ALL FOUR tires changed at the same time unless the other two are near new.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Don't worry about engine mounts, not that expensive.
As above, AWD is the most important check on these. You'll need to google up about the issues with collar sleeve failure and DEM corrosion (check Images on google). It has new tires so no worries but keep in mind, on these always have all 4 tires with same wear or the AWD gets damaged. Same when having a flat and using the spare donut.
- Has thanked: 1611 times
- Been thanked: 4071 times
Don't put a lot of faith in car faxes
A proper, pro Prepurchase inspection is better
