Question about PCV system on a non-turbo 99 V70
readallthebooks
Year and Model: 1999 V70
Has thanked: 1 time
Post by readallthebooks »
so i've got a bad pcv system. slight amount of smoke from the dipstick tube and a slow inflation on the glove test after warming the motor up. is it absolutely imperative that this gets sorted immediately or is the car still driveable? i read that the routing is different on the non-turbo motors and that the pressure does not build and pop out seals like it can on the turbos, but this sounds like myth. there's no other indication of oil loss anywhere... yet.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Search forum for PCV thread by jblackburn and cn90.
For now, lift the dipstick up a tiny bit to let out the pressure until you finished reading those DIY threads.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Could be a valve at the corner of the manifold if your car has that one.
rspi
Post by rspi »
Go to 1:18 on this video:
readallthebooks
Has thanked: 1 time
thanks for the insight. sorry, i couldn't get the video to load. i plan on doing the DIY but the car needs to go on a few long trips soon and i just didn't want a seal to blow out dumping oil on the interstate at 70mph
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
readallthebooks wrote: 19 May 2017, 23:01 ...i just didn't want a seal to blow out dumping oil on the interstate at 70mph
Don't worry that never happens. You may damage seals and have oil leaks but you're not going to dump all of the oil out in one go. A tiny leak is enough to relieve internal pressure.
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
When i was told to let the do sick out a littleness pcv was bad it shit out oil as I began to drive. So be care full of this. It's a pain to clean up all that oil.
