850 anti roll bar
Covert
Year and Model: 1997 850
Post by Covert »
Putting a new anti roll bar on the 850 as the vulcanised bushes on the bar are shot , taken the rear subframe mounts off and dropped the front by 4 turns each .undone all 4 of the bolts that hold the bar to the subframe so it's now loose in the car . Issue is this piece of metal that seems to be attached to the steering rack ?
Any help you can provide will be gratefully received!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
From the picture I can't tell exactly where you are but the rear hydraulic motor mount bolts through the rack. Is this towards the center of the car?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
These iPd instructions should help.
https://www.ipdusa.com/products/4873/10 ... kit-850-70
Covert
Post by Covert »
Thanks folks , Lee you can just about make out the downpipe and flexi on the left ,so this bracket is to the right of the exhaust
The photo is from the back of the subframe shooting fowards towards the front of the car .
The ipd photos dont have this bracket in the pics .....
The anti roll bar is sandwiched between the power steering rack and this bracket it seems .....
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Metal can be unbolt, I did it.
85 GLH, 367 whp
00 Insight, 72 mpg
Covert
Post by Covert »
So have I got the disconnect the steering rack and drop the subframe to do this ?
Covert
Post by Covert »
Hmmm silence ...
Anyway speaking to a volvo nut at work he has advised that the plate above is sandwiched between the subframe and the steering rack so you have to take the subframe out to get the anti roll bar out ....
Its 95% undone , so seeing as ive got to take it out i thought i would replace the bushes and hydraulic engine mounts and have the subframe sandblasted as i really dont want to be doing this job again !
Are the hydraulic engine mounts different front to back or can you just buy x2 of the same ?
Also are the subframe bushes different or again can i just buy x4 bushes ?
I take it the new bushes need to be pressed in ?
Any info gratefully recieved !
Thanks Mark.
Has thanked: 2197 times
Been thanked: 1850 times
On my FWD 850 and V70 the front and back are different part #'s. Looking up on Vida for a Euro spec RHD 94 855T, they are listed as 2 different part numbers.
Rear is listed as: 9434435
Front is listed as: 6801722
These would appear to be the same for all P80's from 92-00 for the rear and front and for manual and auto.
Covert
Post by Covert »
thanks neil.
wonder what the difference is as they look the same .....
dont know if i should change it or not as its not leaking but very easy to change now that the subframe is out .....
do you know if the subframe mounts are all the same ?
Thanks Mark.
rspi
Post by rspi »
Position keys.
