1995 850 GL wagon turbo tire question
goat1234
Year and Model: 1995 850 GL
Post by goat1234 »
:P Hello All,
Have a 95 850 GL that I am restoring. specs say tire size 205 50 15 zr
i have opportunity to get set of 205 65 15s would these work ?
any thoughts would be greatly appreciated
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
i dare ti doubt that you should use 205 50 r15. I think it's rather 205/55 r15 or 205/50 r 16.
The 65 r15s might rub on full lock or full Suspension compression
1996 855 R,
2010 V70 D5,
DeathRex
Year and Model: 1996 850 Turbo
Post by DeathRex »
65s would be 2.4 inches taller than the 50s(23.1in). Is the wheel well in a GL the same as a turbo? Because a turbo has 205/55R16 tires that are 24.9 inches, that would make the 65s only 0.6in bigger than tires that barely fit. Might be worth a try, but I would bet they would rub. On my turbo driver side rear, I measured 28 1/2 inches horizontally right across the hub. Of course your speedometer will be off by quite a bit, maybe 7 mph or so. 65s would also give you a squishier ride.
