My mechanic says I have a bad front (upstream?) 02 sensor. How many are there on this vehicle, and where are they located?
Thanks
Ed
how many 02 sensors on 2000 v70 XC? Topic is solved
Two. One in front of the cat, one behind.
- Has thanked: 316 times
- Been thanked: 531 times
Yup. Upstream is visible from the top, on the downpipe, before the cat.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Hi Ed with a 2000 V70XC, I'm Ed with a 2000 V70XC!
If you're replacing the sensors, be sure to use genuine Bosch parts. That way they are direct plug & play with no splicing required, and you know they're the right specs.
Are you by chance also having any issues with a recurring cat converter code?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 1808 Views
Last post by precopster
- 22 Replies
- 1920 Views
- 773 Views
Last post by donatishane
- 11714 Views
Last post by packetfire
- 706 Views
Last post by SuperHerman
