How many gallons of gas do I need to set this piece of crap on fire and put an end to my suffering???
Everytime I fix one thing another thing breaks. After warring with the P1670 error (replaced the antenna ring that had been destroyed by PO (How??), then got a P0352 cylinder B (#2) faulty new Volvo coil pack. Then P1670 came back on . Re-set the door locks and then all good. Backed the car out of the garage to swap out the other 3 cars winter tires. Go to bring the car back in today, and get a ABS/Brake failure/engine check light and no signal for the trip and mileage (same issue I had with the 'R' a few days ago and went away again). Ran car back into garage threatened it with a lighted match in the fuel tank, and left it in disgrace. Went out again and scanned with my basic scanner and only code that came up was P0600. Re-set it twice, and then re-started the car and all warning lights back off for now. How can I be getting so many random warning lights which I was not getting before. Yes I have done a lot of repairs, but have cleaned all the contacts carefully and then reconnected as I went. So what is going on?
P0600 serial comms problem
- Has thanked: 2199 times
How good is the battery? Low voltage on CANBUS is crippling
Battery is about 6 months old and I just re-charged it 2 days ago and ran the car out of the garage and back in, so only started twice! I will put my battery tester on it and see what is says, as I am at a loss as to why all the weird random issues.
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Hi Neil,
I read through your other thread ( viewtopic.php?f=1&t=81868 ) for the P0600 issue, which I'm now getting along with an SRS light on my '00 V70 n/a m/t, and I was just wondering if you've had that code come up again.
Thanks for all your great documentation on your own 2000 V70.
Bruno
Bruno
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- 6829 Views
Last post by VolvosLocos
- 2807 Views
Last post by psamanni
- 1782 Views
Last post by esl_97_850_T5
- 1033 Views
Last post by jonesg
- 544 Views
Last post by xanthefin
