1998 1999 ECC control unit compatibility question Topic is solved
AKJeeper
Year and Model: 1996 850 Turbo Wagon
Has thanked: 7 times
Post by AKJeeper »
abscate wrote: 19 Dec 2016, 04:55 Climate control changes
In late 1998 the damper and temp control modules were replaced by a single motor (9134729)doing both functions on the driver side. This was used 1999-2000 then replaced on P2
Edited to 1999-00
Does anyone know if the ECC unit (the part in the dash w/ the knobs) from a '98 is compatible with a '99-'00?
Has thanked: 1610 times
Been thanked: 4068 times
I don't think so. ME7 (used on 1999) has completely different management of climate control than earlier.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
AKJeeper wrote: 24 May 2017, 13:08
Edited to 1999-00
Not sure. My ECC unit worked in my cousin's '99 when we were trying to diagnose the issue with it. His damper on the driver's side is shot.
And FCP reports, in fact, they are the same
Screen Shot 2017-05-24 at 3.45.27 PM.png (109.45 KiB) Viewed 1918 times
This is kind of surprising since mid 1999 year, the damper went to the one motor style - but apparently the ECC can figure out how to work with both?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote: 24 May 2017, 13:48 This is kind of surprising since mid 1999 year, the damper went to the one motor style - but apparently the ECC can figure out how to work with both?
Are you talking about MCC or ECC?
MCC has always been just the recirc damper.
ECC for the mid year damper change.
