2003 XC70 Misfire Question (New Plugs and Coils) Topic is solved
nicksorg
Year and Model: 2003 XC70
Post by nicksorg »
Hey guys.
Quick question. Car developed a rough idle and is misfiring. It's my kids' college car so I don't know exactly how long it's been like this. I pulled codes and it reported a misfire on cylinders 3,4,5. Last night I swapped the #1 and #5 plugs & coils, cleared the codes, and drove it today. Codes now show cylinder misfire on cylinders 1 and 2.
I'm going to throw new plugs in, but wondering about coils. Would 1 bad coil impact a bank of cylinders?
Thanks
Nick
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
Start with plugs, but be prepared to replace coils. Obviously you know that you can swap them to see if a misfire follows one coil from cylinder to cylinder.
You should probably also closely inspect all the wires running to the individual coils. If the plastic cracks on those - and it often does - it can cause some weird problems.
For what it's worth, I've had good luck pulling used coils off a couple cars at a local U-Pull-It Salvage Yard. $10 per coil, and the 4 I swapped into any of my cars are still working fine. It's a crap-shoot, but if you're wanting to save money that might be something to think about.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
nicksorg
Post by nicksorg »
Thanks. I put in 5 new plugs and swapped out the coil and it is running better than ever.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Keep in mind with the coils, if one goes, then the set are likely nearing the end of their lives. If you can, change them all, especially for a geographically separated driver. Otherwise/also, educate the drivers to watch for the flashing CEL indicating misfires, so they can get codes read if need be.
Current Volvos:
