Meyle HD Control Arm Bushings, hydraulic?
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Are the control arm bushings on these Meyle HD control arms hydraulic? They look like they're oozing.
Getting some noise from my front end after 2K miles after installing these and am thinking it's finally time to just put Lemforders in here and, "set it and forget it." :lol:
The noise is a low pitch squeal/squish that occurs when accelerating from stop and when stopping hard. Will inspect a little further before making any conclusions.
Retired:
2015 Volvo S60, T5, 85K
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
No,they are not.
It seems that they were lubricated at some point.Could be during the installation or you have some oil leak onto them.
That sound is not from control arms. :!:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
theWIFES_S70
Thanks for the insight, Misha. That's what I thought.
Alright, I'll get the car on jackstands and give everything a look. It's more like a creaaaaak. You don't think that's control arm bushings?
Retired:
misha
Post by misha »
Creaking...yes,but not squealing.
They tend to squeal when rubber dries out.A few squirts of WD-40 will quiet them up.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
theWIFES_S70
misha wrote: 27 May 2017, 15:04 No,they are not.
Misha, I just swapped out my Meyle HDs. I could tell they weren't torqued right when I went to remove them. They came off way too easily. I installed Lemforders. Build quality compared to the Meyle HD is unparalled. But I'm still getting the same noise. Any ideas what this might mean?
Do you think I might have a broken mount somewhere? I have all new mounts in the car: firewall, upper torque (volvo), transmission (volvo), rear (corteco) and front (febi)... even installed new sway end links (lemforder)... You think one of those might have come loose? This sound is driving me up the wall. I did about 2K with that sound (a trip up north) alignment is still good, tires don't show any crazy wear. The Lemforder control arms sound "less" but the same basic sound is there. I'm at a loss for this... Thanks.
Retired:
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Mine tend to squawk, grate and shimmy not squeal/squish. Of course your squeal could me my squawk which makes this very confusing :D
misha
Post by misha »
:lol: :lol: :lol:
Strut mounts?
They can creek when they go bad or going bad.
Did you check them?
Btw....Meyle HD(HD means heavy duty) will outlast every oem bushing or mount.
Regular Meyle is average quality,but HD is premium quality.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
theWIFES_S70
precopster wrote: 12 Jun 2017, 17:31 Mine tend to squawk, grate and shimmy not squeal/squish. Of course your squeal could me my squawk which makes this very confusing :D
hahaha, ok, I get it! Let me try again, it's a low-pitched "rubbery" groan... We really need a youtube channel with Volvo sounds to help!
misha wrote: 12 Jun 2017, 18:18 :lol: :lol: :lol:
Strut mounts?
They can creek when they go bad.
Did you check them?
I hadn't even thought of teaching the strut mounts... Oh man. This is two years into a set of Gabriel Readymounts so they might be on the way out. All I have to do is open the hood and look for play in the mount as I bounce the car up and down, right?
I know these are supposed to be stronger than OE. But they look so much less robust. Here they are in comparison to Lemforders.
Retired:
misha
Post by misha »
No....you have to open the hood,grab the strut mount and twist it left and right.
If it twists it's on it's way out.Depends on how much it twists.
A bit of play is normal on healthy strut mounts when you bounce the front end up & down.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
theWIFES_S70
Thanks for the direction, misha. I will check out my strut mounts tomorrow and get back.
Retired:
