2003 V70 Tie Rods
alexv702003
Year and Model: 2003 V70
Post by alexv702003 »
Hi guys, 2003 V70 2.4 FWD Auto.
I posted the link below to a video of me moving my driver's side tie rod. Passenger side has the same movement.
Is this normal?
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
Being able to "slide" it is okay (if that makes sense), but there should not be any "open play" in it. It should not click or clunk as your trying to lift it up and down.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
alexv702003 wrote: 28 May 2017, 19:36 Hi guys, 2003 V70 2.4 FWD Auto.
Is this normal?
Wow, yep thats quite SHOT to hell.!
Just did mine a few days ago. Mine were not that bad, yours are going to fail .
First tighten them up so they don't click up and down, I would replace asap.
Perhaps they were installed wrong if both have come loose like that. Its a bit of a coincidence eh?
I would go buy parts and not drive as they are unless you absolutely have to, stay off hiways.
I got moog, $66ea at autozone, they have em in stock.
The easy way to remove is to hold the jam nut with large vicegrip wedged against the body or anything that will prevent it from rotating,
then grab the =shaft= of the tie rod with a large wrench and just unscrew it, leave the jam nut alone.
Mine was the exact same length so I didn't bother counting threads.
Screw the new one on tight up to the jam nut, check the other tie rod and also the inner rods, replace any bad ones and then get it aligned.
jonesg
Post by jonesg »
One other thing, getting the nut off the tie rod end can be difficult, some have an allen end , you insert an allen key to prevent the threads from spinning with the nut, spray with your favourite penetrating oil, brush threads with wire brush and it should come off easily.
Other designs have 2 flats you can grab with vice grips, then use a box end wrench to loosen nut.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It's quite worn, it got play to it so will need replaced.
Make sure not to use some meyle or other cheaper brands, it will last 1 year. Lemforder for this part
alexv702003
Thanks for your replies everybody. I'll go ahead and replace these.
Any tips on checking inner tie rods for wear?
alexv702003
Also, when watching the video i posted, is my outer tie rod end installed upside down? The nut is on the top and it seems that most outer tie rod ends have the nut on the bottom.
jonesg
Post by jonesg »
alexv702003 wrote: 29 May 2017, 11:34 Also, when watching the video i posted, is my outer tie rod end installed upside down? The nut is on the top and it seems that most outer tie rod ends have the nut on the bottom.
Mine is the same, doesn't matter.
When the tie rod is disconnected pull the inner section in and out, listen or feel for slop or clicking.
alexv702003
Alright thanks for the info.
I have vibration at highway speeds I can feel through the steering wheel under acceleration as well as just cruising. Could my worn tie rods be the cause of this?
jonesg
Post by jonesg »
alexv702003 wrote: 29 May 2017, 20:53 Alright thanks for the info.
You're lucky the wheels are still on the car, its a time bomb. Change the rods out and test drive it. Then you'll know.
