I have tried to find information on what width of rim I can fit my new 185/65/15 winter tires to. Most information I have found is either very vague or would tend to say the maximum is a 5J (5") wide rim. I think one even said 4.5J. That is nuts as a 185 tire has theoretically a contact patch that is 185mm wide or approx. 7.5" (7.5J) equivalent. There is some one locally selling a good set of Bridgestone summer rims off a S70 which are on Volvo alloys and the tires are a 185/65/15. I believe one of the alloy wheel sets I have is the same rim type supplied with the car and fitted with 195/60/15 tires and they are on (IIRC) a 6J or 6.5J rim. Again I'm sure the sited that were specific about tire width v's rim width said that a 195 tire should be on a 5.5J rim max. Have Volvo got it wrong all these years??? If someone could point me in the right direction I'd appreciate it!
Thanks,
Tire v's rim width rules?
- Has thanked: 2205 times
- yair
- Year and Model: 1997 940 sw
- Has thanked: 1 time
- Been thanked: 3 times
We run 185/65 r15 winter tires on our 850, Volvo steel rims. Didn't had any problems.
yair
1997 940 wagon
2005 XC90
1996 855 Turbo
1995 850 n/a, rest in pieces.
1997 940 wagon
2005 XC90
1996 855 Turbo
Hey, how are you doing?
I am fine with the Volvo steel wheels, that is what the tires are fitted to already. They are horribly rusty and really not worth the effort of sand blasting and painting. I have to check what width they are, but I have a feeling they are 5 or 5.5J width (so narrower) than the alloys which I wanted to use which are 6.5J which is either 1-1.5" wider than what they are fitted to now. I'll take the wheels off in a few days to fit the summer tires and rims and will check that it says on the rims then. In fact I think the steels wheels have the info on the center flange on the outside where the lug-nuts fit, so can be checked just by removing the hub caps.
Stupidly never thought to check Vida as I didn't expect it to list wheel widths in the description, but it does. Steels wheels apparently come in either 6J or 6.5J in a 15" steel wheel, so need to check what I have now.
Been e-mailing with the guys with the wheels for sale. He has confirmed he has a set of alloys the same as one of mine and they are fitted with the 185/65/15 tires on a 6.5J wide rim and they are fine. Looks like I will be ok as long as one of the 2 sets of alloys is straight on all rims.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
6J or 6.5J x15 is correct for 195 or 185 width tires according to my pink slip (they list every possible tire combination you may legally run).
Interesting side note: my 94 T5M already has the Titan rims used on the T5-R listed as possible option
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Thanks Clemens for your reply! That really puts my mind at rest. I can no look later in the summer at which set of spare alloys I have is the better ones and if I keep the car I will have them re-finished in time for winter. Otherwise I will sell the rims and new winters and fit an old set of winter I have to the other set of alloys and sell them also. Too many tires and too many rims! Time for a garage clear out!
- 1044 Views
Last post by MadeInJapan
- 1104 Views
Last post by Rattnalle
- 521 Views
Last post by Adam_Leyva
- 3840 Views
- 651 Views
Last post by jonesg
