850 Clutch Master Cylinder
correllkp
- Year and Model: 1995 850, 1996 960
- Been thanked: 3 times
Just a note on replacing the clutch master cylinder. Some videos/sites suggest loosening the brake booster nuts. One video said there was three...mine has four. And loosen means back off the nuts as far as you can so you can pull up on the bottom of the booster as you are trying to work the master cylinder back in. Also, there are a couple of drain hoses in the way that work against putting in the new clutch. One is from the windshield grill area which you can see clearly. Not sure where the other one comes from but mine became disconnected when trying to get the new clutch in...which actually made the job easier. Now have to figure out where it goes. Also after getting the hoses out of the way and getting the clutch close to getting back in, connect the plastic clutch shaft to the clutch pedal and then pull up on pedal....mine popped right in when I did that.
- 1037 Views
Last post by polskamafia mjl
- 664 Views
Last post by apharvey
- 2052 Views
- 507 Views
Last post by ghansenv70
- 127 Views
Last post by gregoryahunter1
