$800 or best offer! Likely best for mechanic, engine swap, or part out.
96k miles, but odometer is stuck there, maybe 10-20k over that. Computer showing codes for ABS/BCM module failure. Brakes work fine but no ABS, can be repaired for $170. Timing belt etc have not been done yet.
Car was driven with "low oil pressure" light on. PCV and oil system were very sludged. PCV components all replaced. Oil pan and oil intake pulled and cleaned. Fresh oil and filter. After that it sounds like a diesel, white exhaust clouds, has lost some power, but drives and works. Could be head gasket or turbo?
Radiator replaced 2 years ago. Front strut mounts replaced. Newer Continental PureContact tires with plenty of life. Could use new muffler and tip but they are solid and functional.
Exterior in good shape, typical wear for its age but looks good. Interior in great shape, leather is dark, clean, soft, no tears or stains. AC is cold, sunroof works fine and no leaks. AM/FM/CD works fine, with Grom Bluetooth adapter (works as speakerphone, Bluetooth audio streaming, USB or iphone input and controls).
2004 S60 2.5T AWD, parts/repair, $900 obo, Monroe CT
mkbell2000
- Year and Model: 2004 S60
