source for aba hose clamps or equivalent
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
Are these clamps, or something similar that minimizes the risk of cutting the clamped hose, available at any local retailers? I've found them on Amazon (of course), eBay and online (mostly auto and marine suppliers). But I don't need dozens and dozens and shipping can be prohibitive.
But maybe a first question should be, is aba really better than the clamps from Autozone, HD, etc.?
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
They may be slightly higher quality, but as long as you're not pushing the clamps beyond their limits, the Kohler hose clamps from Autozone work just fine. I use them all the time.
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
It sounds like you're looking for what's called a lined clamp. Gates and Ideal make them and any decent parts store should be able to get them for you. But you'll have to ask the senior or commercial salesman to look them up in the paper catalogues for you, or get the part number online for them. Otherwise, Jegs or Summit carries them.
Has thanked: 2203 times
Been thanked: 1852 times
I found mine at a small parts supplier locally in Calgary. They ordered them from a boat supplier in Vancouver. Apparently this style of clamp is more common in marine applications it would appear. I bought some off Amazon, only to find when they arrived they were China copy parts made to look like the real things right down to the color blue on them.
In fairness, they look reasonably well made but with blurry ads on Amazon, they actually say ADA on them.
As I needed a bunch of them at the rear end re-build on my AWD V70R I bought the real thing (ABA), as even the stuff Volvo now supplies is crap. Otherwise locally the only thing that was available are the cheap band style with all the little slots in them and flat sharp sides that cut into rubber pipes.
I should also add the reason for using the ABA clamps is the rounded sides of the clamp are kinder to old rubber hoses. On the AWD where many of the hoses are specially shaped and now obsolete for the emissions and fuel system, you have no choice but to re-use old hoses ore find good used ones as I did. The clamps with the flat sides are very prone to cutting the old hardened rubber and causing them to split.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I get them from the dealer, if I buy enough stuff they sometimes just throw them into the order.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
The point I made earlier, is I bought clamps from the dealer and they are now supplying the cheap flat stuff at high prices. Took them back and told them they should be ashamed!
That was when I went looking for the OEM (ABA). Fortunately with a brother in Sweden, he was able to get me contact info for ABA in NA and they were very helpful helping me find local supplier.
enotslim
Post by enotslim »
Thanks. Found a local place (BelMetric) with comprehensive selection, OK prices and reasonable shipping - cause they're only open m-f 9-5.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Glad you found a good source. It is worth it.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
When at my local salvage yard I get clamps from Mercedes, mostly, as many as I feel like grabbing. 6 bucks for a box full or so. I therefore have a great selection of the best quality clamps found anywhere (ABA as well) at a fraction of the new price, and it's a rewarding task as well. I even go home, lubricate and polish them up, which is a bit nuts, I know.
