1994 850 Turbo Wagon - Random Stalling
Cbruns850
Year and Model: 1994 850 Turbo
Post by Cbruns850 »
A while ago I posted here about an issue I had with my '94 850 Wagon. It kept stalling at odd times, either when the car was cold and I had driven it 2 miles or right before I got to work (25mile drive one way), didn't matter when or where. It would randomly stall. Recently replaced the fuel filter and battery and also bought a 1994 compatible OBD II code reader. Ran it this morning and it's showing no codes whatsoever. I've replaced the air filter, done an oil change and replaced the oil filter as well. I'm pretty much at my wits end as to what is wrong, I do know the turbo needs to be replaced within the next 6 months, but not sure if that would cause an issue. Any help is greatly appreciated!
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Fuel relay?? worth a shot
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
+1 on Fuel relay and try installing a multimeter setup to measure current across your fuel injection fuse. See how much juice that pump is pulling at idle.
When it stalls out does it still sound like the pump is running for a second or two after the car dies? Do you still have instruments when it cuts out?
2023 Lexus RZ450e -66k
Cbruns850
Post by Cbruns850 »
That definitely could be, would the fuel pump matter at all?
Cbruns850
Post by Cbruns850 »
wizechatmgr wrote: 31 May 2017, 15:55 +1 on Fuel relay and try installing a multimeter setup to measure current across your fuel injection fuse. See how much juice that pump is pulling at idle.
I still have instruments when it stalls, and I have heard the pump keep going after it stalls. I'm also trying to DIY on this so havnt used a multimeter setup.
Cbruns850
Post by Cbruns850 »
Cbruns850
Post by Cbruns850 »
Just to double check, the fuel relay is this?
wizechatmgr
Not sure on your year but mine on the 99 looks like that plus 2 small terminals.
Would suggest just pulling yours out and jumpering it to see if you get a difference. Robert's channel has a good video on that.
Cbruns850
Post by Cbruns850 »
Found the part, and ordered it. Fingers crossed this is the issue! Thanks for your help. Hopefully no further issues
