Looking at buying a 2007 S40 2.1i with 115000 miles. Super clean but the check engine light is on, had the codes checked and it came up 2 error codes:
P050B - cold start ignition timing performance
P0012 - intake (A) Camshaft position timing - over retarded (Bank 1)
Can anyone enlighten me on if this is something that is hopefully a tune up issue or something more major. Car runs good other than a slight vibration in the front end as you take off, possible a tire issue.
Any help is very much appreciated.
2007 S40 2.1i Check Engin Codes Topic is solved
Ok, follow up on what was found during a preliminary mechanic look. Exhaust timing has slipped and it throws the code after a full throttle pull. Going in for timing repair next week. They said the timing pulley is a press on fit for my year and they are not sure why it has moved. wont know exact reason until it is fully apart. So where we go...
- Has thanked: 17 times
- Been thanked: 35 times
Any resolution with your car?
Great news!!
- 6370 Views
- 1797 Views
Last post by Samzebian
- 860 Views
Last post by Iceman12596
- 451 Views
Last post by denea
- 701 Views
Last post by NTXC
