Volvo 850 no start with no Blink Codes - bad coil Topic is solved
Vanillagrila
Year and Model: 1995 850 Wagon
Post by Vanillagrila »
Hello! I have a 1995 Volvo 850 Wagon, and recently the engine stalled suddenly, and won't start up (cranks fine). I have no check engine light, but when I try the blink codes on connector A2, I get nothing! Not even the 1-1-1 code! The only code I see is from the transmission computer for "Open or short on torque limiter circuit" which I'm blaming on the fact that the ECM isn't on. I couldn't find a pin-out for the ECM but I am guessing that the larger pins are the power and ground pins. There is no Voltage on those pins. The fuse is fine (its shared with the TCM). Is there another relay somewhere that turns on the ECM?
I already tried another ECM that I bought from eBay with the same results. Any help would be appreciated. Thank you!
Vanillagrila
Quick update.... found a wiring diagram (not sure how applicable it is) and apparently the pin that the ECM is powered by is pin A30. With ignition on, there is no power on that pin. I just bypassed the fuel pump relay just to rule that out... still no start.
Vanillagrila
main fuel system relay also isolated and ruled out as a suspect.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Vanillagrila wrote: 02 Jun 2017, 16:53 main fuel system relay also isolated and ruled out as a suspect.
The grey one on cooling fan carrier?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Vanillagrila
Yes the grey one on the cooling fan carrier is working properly.
Vanillagrila
So it turns out that my Ignition coil shorted out, causing the ECM to switch off, which caused my tranny code. Replaced the Ignition Coil and the car started right up.
Thanks to anyone that took the time to look at my post!
