I'm planning to replace the fluid in my 96 base (which also has a clutch). I don't want to power flush it, so will use the fill reservoir, helper will pump brake, open-close bleeder nipple method. I'm a little concerned about getting air in the clutch line, it's working fine now so don't want to mess that up.
Does the brand or dot rating matter?
EDIT:
I just found this discussion. Indicates Dot 4 was specified in owners manuals mid 90's.
Volvo 850 brake fluid Dot 3 or 4?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Dot 4 or dot 4+ max.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
No, all brake fluids are synthetic though.
What you don't want is DOt5 or silicone based fluid.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I haven't added brake fluid since I bought the car 5 years ago, so I suppose it has Dot 3. Is that generally compatible with Dot 4 or do I need to be sure to do a complete flush?
It came with DOT 4, but I'm sure someone changed it
DOT 3 and 4 go together like third rear seats and radio codes
Here's a thread on DOT 4 and DOT 4+
viewtopic.php?f=1&t=50795
'MY Lord,,I didn't even know there was a DOT 4 +. Why do they keep changing things? I like my world like 1955.
As long as no one moves the time slot for Matlock.....
- misha
If you go back to post #2 you will find out.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I missed that Misha. It looks like a higher BP spec which probably is irrelevant for our cars
- 3034 Views
- 1495 Views
Last post by darylrobert
- 3485 Views
Last post by Krons
- 2339 Views
Last post by cork5695
- 1618 Views
Last post by moonweasel
