Hi guys,
Just out of curiosity, I need to replace front discs and it appears the right P/N is: 31400739, 31262706 (whatever has replaced the other).
To be sure, I measured the old rotor: 11.25" or 286mm, so no doubt the above P/N is correct.
However, VIDA says: 15", O DIA 286mm, REPL 1 PCS 31262706
My question is: 15" wheels? I have two XC70, both on 16" with the above P/N installed.
When I look at Tasca, they also say the for 15" wheels.
On the other end, VIDA gives P/N 31262707 12"or 305mm for 16" wheels.
I do not get this.
Any clarification is much appreciated.
Thank you,
Alex
New Front Brake Rotors - which size?
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
I think VIDA might be saying that if the rotors are 305mm dia the wheels need to be minimum 16'' to fit with adequate clearances ?
The 285mm dia rotors would suit both 15'' and 16'' wheels.
- 1192 Views
Last post by MadeInJapan
- 15 Replies
- 37109 Views
Last post by chitownV
- 1927 Views
Last post by SpeedyPete
- 35 Replies
- 9002 Views
Last post by Yendor72
- 619 Views
