Ok, I know this is probably simple, but perhaps someone with experience can keep me from damaging the interior door panel while removing to check the actuator. Is there something that "typically" goes wrong on these doors. Does anyone have a diagram?
Yours,
Bill Martin
Driver side rear door won't unlock - others work fine Topic is solved
firstvolvo
- Year and Model:
I took it apart and found that the lip that holds the panel to the top of the door had unglued off. I glued it back on and now my problem is worse. When I unlock the car and try to open the driver door, it almost always re-locks now, whereas it only used to do it once in a while. I think the problem is that the rod that holds the button got bent. I'm going to re-attempt the fix and let you know how it goes. If anyone lese has a suggestion, please share.
Nathan
99 S80 T6
99 S80 T6
- 3441 Views
- 963 Views
Last post by chefmarkt69
- 1010 Views
Last post by jbkeene
- 2150 Views
Last post by chrism
- 1322 Views
Last post by DavidE7
