XC70 subframe washer plates Topic is solved
norski
Year and Model: 2004 xc70
Post by norski »
How many of these large washers are supposed to be included when you bolt the subframe up to the frame? There were only two on my car. I bought the car new in 2004 and nobody has been into the subframe since purchased. The pictures included for the subframe mounting and bushing kits only show two washers (but at least one supplier lists that 4 are included in the kit even though the picture shows just two). Without the large washers though, the subframe bolt just pushes on the center rubber part of the subframe bushing. I don't understand why two of these bushings don't have the large washers?
Also there are white plastic bushing (guides? not sure what they are called) that are attached to the frame and the center of the subframe bushing slides over that guide. There are only two of those as well leaving the other two subframe bushings to simply wobble around with only the bolt penetrating the bushing. Are there supposed to be two or four?
Did Volvo forget to install these components on my car?
Arne
norski
Post by norski »
Screen Shot 2017-06-10 at 7.51.07 PM.png (93.73 KiB) Viewed 2368 times
Here's a picture of the large washer plates.
norski
Post by norski »
Anybody? The plastic bushing guides hang down from the main frame. They reveal themselves only when you drop the subframe. They are about 1 inch in diameter and the subframe bushings fit nicely over them. Why would there be only two instead of all four bushings?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
A photo of your setup would make it super easy to see what you mean.
The washers you provided pics of are fitted to the front two positions. On the rear there are 2 large plates with 3 holes.
norski
Post by norski »
Help! 77 views and no replies? I'm sure my description is confusing but I don't know the exact name of the parts. Did Ingmar at Volvo forget to install these parts?
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Been thanked: 4 times
Post by Botbasher »
precopster wrote: 11 Jun 2017, 18:00 A photo of your setup would make it super easy to see what you mean.
Precopster hit it on the head for you... 2 in the front and 2 plates in the rear.
Pics are a big plus for clear quick answers! Here's what your fronts should look like.
Here is what the rears will be (being installed in this pic obviously).
zzz rear sub bushing plate.jpg (75.75 KiB) Viewed 2277 times
Hope that helps.
K "bushed" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
Botbasher
Post by Botbasher »
Of course you always find the better pic 2 seconds after you hit submit...
zzz both bushings.jpg (48.97 KiB) Viewed 2275 times
Cheers!
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
norski
Post by norski »
Thanks guys. Yes that was a big help. Resolved!
