I have a '93 850 and the left hand, front turn signal quit working. The bulb is fine and the fuse is okay (had to be since all turn signals go through it) I looked around and apparently this car does not have a signal relay. Is the relay incorporated in the stalk? If so, is that the next logical part to swap out?
Thanks in advance,
Ken
Signal lamps Topic is solved
kendpotter
- Year and Model: 1993 850 GLT Sedan
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
It's built into the hazard light switch.
But if all of the others work, it's OK.
I'd look at the individual lamp, socket
and that socket's ground connection.
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
+1 on examining the lamp, bulb, lamp connection pins and associated wiring - I had problems with one when the insulation on the wiring exiting the connector became brittle and broke causing a short. You should be able to pull the whole assembly out fairly easily - I think its only held in by a spring, or is that the S70 signal?
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- Has thanked: 316 times
- Been thanked: 531 times
850 is just a spring, probably a little less susceptible to breaking than the plastic "spring" on the S/V/C70.
Check out the wiring and the connector. It's possible that the terminal slipped out of the plastic connector or the terminals are corroded.
kendpotter
Thanks for the help everyone.
- 5521 Views
Last post by AnyMajorDude
- 8895 Views
Last post by rhubarb
- 1006 Views
Last post by obayha
- 581 Views
Last post by mrbrian200
- 995 Views
Last post by volbul2
