99 S70 Parking Brake Guidance
Brucebo
Year and Model: 850 '96, S70 '99
Has thanked: 3 times
Been thanked: 5 times
Post by Brucebo »
Anybody have an guidance on how often the parking brake shoes need replacement? I need to replace the disc brakes and rotors and am wondering if I should buy a set of parking brake shoes too. The parking brake is currently working fine. How long do the parking brake shoes last? If I wait to look it will be too late (or do the work twice).
-B
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
They are just that....parking brake and work only when you pull the parking brake handle.
They don't wear at all but have tendency to fall appart...friction material separating from carrier just from heat of the rotor.
You will see their condition when you pull the rear rotors.
If they are fine...leave them.If not...replace them.
Even if you need to replace them later,it is a 30min job for both sides.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4072 times
Bruce - by the parts local so you can return them, when you pull the rotors, evaluate and replace if they look either thin or if they are falling off. Mine lasted about 12 years/140k on my 99 but were used daily.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Same here, mine failed at around 150k and the liners separated. I would replace them as preventative maintenance if your car still has the original ones and is at around this mileage.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
