Volvo Radio From hu603 To hu803..?
JRL
- Year and Model: Several
- Been thanked: 16 times
You mean HU 613, there is no 603 radio
You will need to buy the underseat amp and harness, otherwise it's an easy swap
The 803 runs off a 300 watt underseat amp, the center channel works off the radio.
Oh, you will also need the center dash speaker, the wires (harness) that goes from the speaker to the 803 is built in all these cars, so no worries there.
If you successfully do this, you will probably want to add better aftermarket door speakers as now it will pack a pretty good wallop and if turned up it will easily overpower the OEM speakers!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
JRL told you the exact changes you have to do, I'm not sure what wasn't clear? You have to do that if you want the HU-803 to work. The HU-803 won't work without an amp. As for the connectors, behind the radio there is a grey connector hidden somewhere wrapped in a white foam, this will connect to the grey plug coming from the amp harness, then the green plug will go into the back of the radio. Then the DIN connector from the amp goes as well into the back of the radio.1bigb1 wrote: 13 Jun 2017, 23:40 NO No , I have a HU603 in my Volvo V70xc and I would like to know if I could change / upgrade it to the HU803,if the connector plug is the same and what changes do I need to do if so..????
- 11 Replies
- 10703 Views
Last post by JRL
- 4202 Views
Last post by 850TurboTurtle
- 1660 Views
- 3478 Views
Last post by matthew1
- 2064 Views
Last post by Ben850
