Hello,
Can anyone tell me if the angle gear from a 2004 XC90 T6 will fit my 2003 xc70?
Also rear diff and AOC.
Thanks
Bero
Angle Gear Replacement
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
Go to the Volvo Online Parts Store and put in your year info and find all your part numbers.
Then put in the year info for the car you want to loot the parts from. If they match, you have bolt on compatibility! HuRah!!
If you are looking for Bolt-On compatibility with mis-matching part numbers, then yes, you'll need someone who has done it to chime in, or to find a JY donor and compare the parts directly in the yard (been there, done that many times!!).
Good luck with it and hopefully you'll document out the swap as I am sure there are a lot of upgraded parts on those XC90s that would last a lifetime on the puny little XC70s!!!
Cheers!
K "swapped" S
Cheers!
K "swapped" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
- 16 Replies
- 4098 Views
Last post by Chili58
- 835 Views
Last post by JRL
- 11 Replies
- 3000 Views
Last post by nadvolv
- 774 Views
Last post by mkiehna
- 4314 Views
Last post by darrylrobert
