96 850 warm air out of vents
DeathRex
Year and Model: 1996 850 Turbo
Post by DeathRex »
I'm getting warm air out of the vents even with it set all the way to cold. When I turn the AC on, it works fine, but I'm thinking there is a bit of radiator fluid going through the core. Chilton's says there is a heater water control valve, but I can't find it.
Has thanked: 1610 times
Been thanked: 4065 times
There is no heater water valve, these Volvos run full flow through the heater core at all times.
The hot air is selected by the blend air motor which blends heated and AC or outside air. That motor is probably faulty.
DeathRex
Post by DeathRex »
OK, so I should be able to hear the motor when I go from cold to hot.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Or your center vent outdoor air blend wheel is open.
