2001 Volvo S60 T5
8K miles
While showing off the car I found that the gas tank cover does not lock when the car is locked. I uncovered the locking mechanism through the trunk and found that if I manually engage the lock, the solenoid will unlock the door but will not relock it. It seems the solenoid is only working in one direction.
Any ideas?
Gas tank cover does not lock
it's nearer 8 minutes!
Don't you have a hand book - says it all in there.
Next thing to catch you out - which isn't documented is the air-con blower coming on when you've been parked up for a while. This usually occurs about an hour after you've parked - and dries out the condenser to prevent mildew/bacteria and nasty smells.
vipes
vipes
- 1442 Views
Last post by joevar
- 774 Views
Last post by MadeInJapan
- 767 Views
Last post by cn90
- 1039 Views
- 204 Views
Last post by cn90
