(2001 V70 T5) I have a defective automatic rear view mirror. I've checked out the vids on replacing the glass only, how to separate the old mirror from the circuit board and transfer the CB to the new mirror, etc... I can get the glass from a parts yard, and there is one question I could use an answer to:
When I go to pull the part from the donor car, can I simply separate the front and back of the rear view mirror housing, then unplug the circuit board, instead of removing the entire assembly? It looks like all I need to do is to insert a screwdriver between the two pieces and pop it apart..
Thanks in advance...
Rear view mirror replacement
JRL
- Year and Model: Several
- Been thanked: 16 times
See post below
precopster
- Year and Model: Lots
- Been thanked: 128 times
If your 2001 has a separate key you can ask the wrecking yard if they have a working remote fob to match that donor car. If so simply swap BOTH fob and mirror as an entire assembly.
Saves time and frustration.
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
thanks for the tip, but the donor car didn't have any keys. It would be much easier to change the fob than the circuit board in the mirror, for sure.
Besides, my fob quit working when I changed it's battery. Next on the list....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Actually, there are methods for transfer data from old (original) mirror to replacement. And, there is way for reset used remote control also, and program it to mirror like new remote control.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
You need the special Yagger magic!!! The man has skillz!!!
+1 for anything dealing with him!!
KS
KS
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
- darylrobert
- Year and Model: V70 240 740t xc70
- Been thanked: 44 times
I'm repairing mine at the moment, yes to get the casing apart you pry but your arms will pain, much easier to remove the whole mirroe and light as a unit. however dont pry the mirror off use a long blade
azureblue
Thanks. I was lucky enough when I went to the parts yard to find the mirror assembly already removed from the donor car. Thanks for the caveat about not using a long blade to remove the donor mirror. I hope today I can take apart the donor rear view mirror assembly..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 1239 Views
Last post by senornose
- 641 Views
Last post by Lucky_Seven
- 1135 Views
Last post by phils94850
- 1015 Views
Last post by jimmy57
- 824 Views
