I picked up a cable to scan my car for codes and use VOL-FCR. I have a 1998 V70 AWD.
I have both FCR 1.3.6 and FCR 1.7.6 installed on a Windows XP laptop. Both programs load up and work properly but when I go to connect to the OBD using the cable the programs I get an error.
The cable I have: http://www.ebay.com/itm/KKL-port-RS232- ... rmvSB=true
Any thoughts to what I could be missing?
Chris
Problems setting up VOL-FCR Topic is solved
galexie64
- Year and Model: 1998 V70 AWD
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
1964 Ford Galaxie 500XL 2 dr fastback, 390 thunderbird, auto, AC
1970 Ford F250 Custom Explorer Camper Special 390/C6
My Car Blog
1984 RX-7 GSL-SE
My Car Blog
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
No idea, but I use the obd to USB cable with the ftdi chip.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
kaneelschep
- Year and Model: '96 850 2liter t5
Is your cable set to com 1?
Vol fcr only works on 1.
I have a vag com usb cable. And it works great with the program.
As long as the driver is installed correctly and set to com1.
- cmblackburn
- Year and Model: 1998 S70 T5M
- Been thanked: 7 times
I have no experience with the cable you're using, I ordered a $12 Vol-FCR cable 4 years ago from eBay and it has been perfect since. COM1 and Win95-10 have all worked for me. I suppose I could crack it open and see what chipset it is.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
galexie64
Did you have to load a driver for the cable or did it just work?
I'll go back and make sure the serial port is set to com1.
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
1984 RX-7 GSL-SE
My Car Blog
- cmblackburn
I haven't had to bother with a driver in windows 95, 98, 2000, XP or 7/10.
kaneelschep
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Just install the software,connect the cable and set it to COM1 port.No drivers needed for cable.
Key must be in pos II,in order to make comms with vol-fcr.
You installed drivers for wrong cable btw.For serial cable,drivers are not needed.You use drivers for virtual COM1 port.
Remove it and try again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
galexie64
So I figured the problem out. When I reinstalled the center console, I forgot to plug the port back in. I try not to make dumb mistakes like that.
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
1984 RX-7 GSL-SE
My Car Blog
- cmblackburn
That'll do it! I've made that mistake before, too.
- 39 Replies
- 30758 Views
Last post by bmdubya1198
- 2550 Views
- 770 Views
Last post by Noerty
- 1039 Views
- 11 Replies
- 6870 Views
Last post by ZuluR
