Hi guys
I'm on eEuroparts right now and looking at this https://www.eeuroparts.com/Parts/73794/ ... e-A807802/
It specifically says it's for an automatic transmission. But when I was doing my manual swap, the old axle from my automatic fit right in. Can anyone confirm that they are the same for both transmissions? I'd rather not wait 15 days for the IPD one to ship. Thanks!
97 850 Different Front axles for standard?
dairyqueen814
- Year and Model: 1997 855 NA
1994 850 Sedan NA Black, 343,000mi - Crashed and parted
1993 850 Sedan NA Red, 240,000mi - Now my little brother's car
1994 850 Wagon NA White, 251,222mi - Sold
1997 850 Wagon NA Red, 105,000mi - Currently my pride and joy
dairyqueen814
So I can just plug and play without a worry in the world? Thanks!tryingbe wrote: 19 Jun 2017, 13:04 From factory, manual axles are THICKER than automatically axles. HOWEVER, you can use auto axles in manual cars or vice versa.
- Has thanked: 316 times
- Been thanked: 531 times
You might want to order an automatic axle seal as well if the manual axles are thicker in diameter. It's easier to change both at once than have to go back and remove the axle again to change out the seal if a leak starts. I still need to replace one of my seals.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Please don't spared rumors.bmdubya1198 wrote: 19 Jun 2017, 15:41 You might want to order an automatic axle seal as well if the manual axles are thicker in diameter. It's easier to change both at once than have to go back and remove the axle again to change out the seal if a leak starts. I still need to replace one of my seals.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
tryingbe
Yes.dairyqueen814 wrote: 19 Jun 2017, 15:20So I can just plug and play without a worry in the world? Thanks!tryingbe wrote: 19 Jun 2017, 13:04 From factory, manual axles are THICKER than automatically axles. HOWEVER, you can use auto axles in manual cars or vice versa.
https://ozvolvo.org/discussion/1714/850-v70-axles
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
So the automatic and manual axle seals are the same? They look slightly different in pictures (the manual one actually looks thicker). Sorry, I was just adding a thought since it seemed to make sense.tryingbe wrote: 19 Jun 2017, 17:40Please don't spared rumors.bmdubya1198 wrote: 19 Jun 2017, 15:41 You might want to order an automatic axle seal as well if the manual axles are thicker in diameter. It's easier to change both at once than have to go back and remove the axle again to change out the seal if a leak starts. I still need to replace one of my seals.
Nevermind, just checked out that link, makes sense now. I thought you meant the whole shaft was a different diameter, not just the axle itself.
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
I have used the same axles in automatic, manual turbo, 10 valve and 20 valve cars, there are differences in the shaft diameter but the two ends and support bearing are the same as is the seal facing- I suspect that if not already all the 'new' axles are the same, built to the lowest price pont
- 1156 Views
Last post by Salomons Driveway
- 900 Views
Last post by Eddystone
- 1261 Views
Last post by Seaway
- 2083 Views
Last post by erikv11
- 3952 Views
Last post by PoppySheaf
