850 pnp post just snapped off at the threads
Jaybar
Year and Model: 95,97 850
Post by Jaybar »
It snapped off flush with the cable bracket :o
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I think you are kinda effed with that one. The switch does come apart so you might be able to grab a switch from a junk yard and change the internals without going through the connector hassle. It is really odd that it broke there, I don't think I have ever heard of that particular failure.
Jaybar
Post by Jaybar »
lol the rod that comes out of the trans with the threads broke. Do i just tack it with a weld or JB weld it this is not a fancy 850. The post is still there to do the PNP but i cannot bolt cable on
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Can you post a photo of the problem?
Jaybar
Post by Jaybar »
even worse I changed out the PNP and the shift bracket is laying on the shift post hasn't moved but up arrow is back AARRGGGHHH
Jaybar
Post by Jaybar »
Fixed problem with arrow. duh forgot to plug throttle body sensor in. The square rod that comes out of the transmission with the threads on the top broke off but there was enough meat to get shift cable bracket on and I JB welded it
Has thanked: 2209 times
Been thanked: 1852 times
Hopefully the latest fix is the answer to the issue at last. Know how frustrating it can be when chasing ghosts!
