Volvo 850R - 2nd gear popping out
arturjarn1
- Year and Model: 1996 850R
- Has thanked: 1 time
So i a probleme accured, when driving my car in second gear sometimes it popsout to neutral, it happens on deacceleration, dosent happen on acceleration, i think i need to chnage the trans ? How to find my transmission type ? Thank you for help!
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
For a limited time in 1996 only, Volvo offered a new heavy duty manual transmission designed specifically for the 850 R (excluding US market), called the M59, which featured a viscous coupling limited slip differential. Furthermore, the M59 equipped cars were fitted with the B5234T4 2.3-litre 5-cylinder engine featuring a larger TD04HL-16T turbo, re-designed turbo manifold & intercooler, unique ecu with Motronic 4.4, uprated fuel pressure sensor and a heavy duty clutch.
From Wikipedia
Before you go that far; how are your torque strap and buckle mounts? (the one at the top Left rear of the motor, and the one under the front left of the car?) I know these cars use cable shifting but? worth a look.
From Wikipedia
Current Volvos:
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I had this problem in 3rd gear on my S70. Only happened decelerating downhill. Occurred soon after I bought the car for a couple months and hasn't happened for a long time now. I attributed it to not being driven for a while. Not sure how similar the 98 S70 T5 and 96 850R transmissions are to each other (I'm assuming pretty similar), but I know if the shifter bushings wear out it can lead to problems with shifting and a sloppy shifter.
Knows enough to be dangerous
arturjarn1
Ye, all is right, but i have italian version, but it sure does have lsd! Il check thoes mounts and il let you know ! any idea where to buy somekind of better bushings? Like steel ones or something?FLXC90 wrote: 23 Jun 2017, 15:56 For a limited time in 1996 only, Volvo offered a new heavy duty manual transmission designed specifically for the 850 R (excluding US market), called the M59, which featured a viscous coupling limited slip differential. Furthermore, the M59 equipped cars were fitted with the B5234T4 2.3-litre 5-cylinder engine featuring a larger TD04HL-16T turbo, re-designed turbo manifold & intercooler, unique ecu with Motronic 4.4, uprated fuel pressure sensor and a heavy duty clutch.
From Wikipedia
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
arturjarn1
The shift cable bushings are changed and they cannot cause the issue.
- 2390 Views
Last post by dairyqueen814
- 1650 Views
- 747 Views
Last post by Clemens
- 716 Views
Last post by mapdoc
- 7805 Views
Last post by oragex
