Hi all. Can anyone show me wiring schematic for ECT - Temp gauge?
New Volvo sensor, checks out w/meter.
> Had cluster out for Odo gear fix. Did work for a few days. Now zilch.
What is electron flow to / from gauge?
Thanks, Jeff
Temp gauge 'inop'
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have had those temp gauges go out. Check temp with OBD2 reader live data.
- whilst
- Year and Model: 1995 854T
- Been thanked: 2 times
cn90, I cleaned up that connection.
rspi, Robert, actually had a Temp gauge go out? By itself?
Can anyone tell me where voltage comes from/for/to ECT to gauge ?
ECU?
Thanks all.
Jeff. 256K and running better than it ever has! (Except for Trans - Reverse slipping*#@&! anybody ever figure out what exactly causes this?)
ECU?
Thanks all.
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
Assuming you are talking about Temp Gauge on a 1995 854T:
- download the (primarily 1995) Volvo 850 Service Manual,
- expand it (for ease of individual file access in future),
- open "instrument panel.pdf",
- search for the TEMPERATURE GAUGE TEST section on pgs 8-10 (of 22).
There are several tests there, using the under-the-hood diagnostic connectors, to isolate where the problem is. The last paragraph of that section (ie, just before the TACHOMETER test) is probably the most important one for you.
My guess is that when you reinstalled the COMBI (instrument panel) you didn't hook up the connector thru which the Motronic 4.3 feeds the engine coolant temp values to the COMBI. Or the connector is not seated firmly. Or a wire was inadvertently broken. Or??? I doubt that the Temp Gauge is bad, since the problem didn't manifest until your removal / reinstallation of the COMBI.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- rspi
Contact rspi..
Yes, the gauge itself. If you pull the cluster, then take it apart, you can replace the gauges individually.whilst wrote: 25 Jun 2017, 08:26 rspi, Robert, actually had a Temp gauge go out? By itself?
Also, I did test the cluster with the instructions mentioned above.
- 375 Views
Last post by Roger_850T
- 430 Views
Last post by Rbaratt
- 1143 Views
Last post by Stu70
- 1351 Views
Last post by FLXC90
- 2850 Views
Last post by 98v70dad
