91 740 speedometer reading erratic
Hello, the erratic speedo can be caused by two things. The first is a failing speedo gear (gotta look that up). The second is the speed sensors. My 92 has one speed sensor in the rear dif cover and those wires tend to get worn and break, check that. The 92 also has a sensor in each front wheel and they don't fail often. HOWEVER the tone ring behind the brake disk gets very rusty and loaded with dirt. Clean those up with a wire brush and emery paper and you may have affected an easy fix.
- 653 Views
Last post by brickhead
- 4961 Views
- 1984 Views
Last post by harryhendo
- 1086 Views
Last post by 1990Volvo740
- 3443 Views
Last post by precopster
