How to fix / replace key fob?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mdewalle
Year and Model: 2001 V70 2.4T
Has thanked: 23 times
Post by mdewalle »
I have 2 key fobs with my 2001 V70 and each has come apart. I attached a pic; not sure it's easy to see. But the little screw that keeps it together no longer stays put. It is threaded into plastic and I'm sure the plastic threads are worn out. Both fobs have the same problem.
Can I order replacement fobs? I assume that's pricey. I considered putting it together with super-glue, but then I'll never be able to replace the battery again. For a while I put black electrical tape around it, but that's ugly, sticky and doesn't hold.
I can't be the first one dealing with this. Any suggestions? Thanks!
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Looks not very expansive ))
also, you can use Best Offer option.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
The reprogramming can be a bit expensive. I "think" you can transplant the inurds from the old case to a new one. It seems I recall seeing new empty cases on ebay in the past.
In the mean time, that silver HVAC tape with the peel-off backing works quite well at holding it together - been doing that the last few years myself. The silver and black color contrast kinda gives it a high tech look ;)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Get a slightly larger self tap screw.
Heat the screw, clamp the 2 halves tight and thread the hot screw into the plastic, unclamp when it cools.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
A small drop of epoxy on each side of the remote should do the trick.
LIGHTLY clamp shut (or tape) overnight and you should be good to go!
Install a new battery first, this now should last years!
mdewalle
Post by mdewalle »
Thanks guys! Good suggestions.
